Session Media Flow Policing
Session media encompasses RTP and RTCP flows. In order to select policing constraints for these flows, the Oracle® Enterprise Session Border Controller watches for the codec specified in an SDP or H.245 message. When a match is made between the codec listed in an incoming session request and a configured media-profile configuration element, the Oracle® Enterprise Session Border Controller applies that media-profile's bandwidth policing constraint to the media flow about to start.
If multiple codecs are listed in the SDP message, the Oracle® Enterprise Session Border Controller will use the media-profile with the most permissive media policing constraints for all of the flows associated with the session. If a codec in the H.245/SDP message is not found in any configured media-profile, the Oracle® Enterprise Session Border Controller uses the media-profile with the most permissive media policing constraints configured. If no media-profiles are configured, there will be no session media flow policing.
If a mid-call change occurs, bandwidth policing is renegotiated.
