ASR Constraints Configuration
To configure ASR constraints:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type
session-agent and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# session-agent ORACLE(session-agent)#
- If configuring an existing session agent, enter the select command to select the session agent.
min-seizures—Enter the minimum number of seizures that when exceeded, cause the session agent to be marked as having exceeded its constraints. Calls will not be routed to the session agent until the time-to-resume has elapsed. The default value is
5. The valid range is:
Minimum—1
Maximum—999999999
min-asr—Enter the percentage you want as the minimum. If the session agent’s ASR for the current window falls below this percentage, the session agent is marked as having exceeded its constraints and calls will not be routed to it until the time-to-resume has elapsed. The default value is
0. The valid range is:
Minimum—0
Maximum—100
Save and activate your configuration.
The following example shows a session agent configuration.
session-agent hostname 192.168.1.6 ip-address port 1720 state enabled app-protocol H323 app-type H323-GW transport-method realm-id external description carriers allow-next-hop-lp enabled constraints enabled max-sessions 0 max-inbound-sessions 4 max-outbound-sessions 5 max-burst-rate 0 max-inbound-burst-rate 10 max-outbound-burst-rate 1 max-sustain-rate 0 max-inbound-sustain-rate 0 max-outbound-sustain-rate 0 min-seizures 5 min-asr 50 time-to-resume 30 ttr-no-response 0 in-service-period 0 burst-rate-window 0 sustain-rate-window 0 req-uri-carrier-mode None proxy-mode redirect-action loose-routing enabled send-media-session enabled response-map ping-method ping-interval 0 media-profiles in-translationid out-translationid trust-me disabled request-uri-headers stop-recurse local-response-map ping-to-user-part ping-from-user-part li-trust-me disabled in-manipulationid out-manipulationid p-asserted-id trunk-group max-register-sustain-rate 0 early-media-allow invalidate-registrations disabled last-modified-date 2006-05-12 19:48:06
