Request URI Construction as Forwarded to SAG-member Session Agent
The Oracle® Enterprise Session Border Controller constructs the request URI for a session agent selected from a session agent group by using the value of the selected session-agent target. This default behavior enables features such as trunk groups and ENUM to work properly. However, care must be given when the hostname parameter is not a resolvable FQDN. Use the sag-target-uri=<value> option to override the default behavior.
The value can be set to either:
- ip - request URI constructed from
- host - request URI constructed from
This option is global and is configured in the sip-config configuration element.
