H.323 Alternate Routing Configuration
This section describes how to enable H.323 alternate routing. There is a new parameter, and the behavior of the pre-existing response-tmo and connect-tmo parameters change when you enable this feature on your system.
To enable this feature, you need to set the new alternate-routing parameter in the global H.323 configuration to recur. The other option for this parameter is proxy, which means that the Oracle® Enterprise Session Border Controller performs in the way it did prior to Release 4.1, i.e. try only the first matching local policy next hop that it finds.
You configure H.323 alternate for the global H.323 configuration.
To enable H.323 alternate routing:
