If you are adding this feature to an existing configuration, you need to select the configuration (using the ACLI
select command) before making your changes.
egress-realm-id—Enter the name of the realm you want defined as the default egress realm used for ping messages. The
Oracle® Enterprise Session Border Controller will also use this realm when it cannot determine the egress realm from normal routing. There is no default value for this parameter.
