ARIA Support Configuration
ARIA support is enabled at the sdes-profile level.
  1. Use the following command sequence to move to sdes-profile Configuration Mode.
    ORACLE# configure terminal
    ORACLE(configure)# security
    ORACLE(security)# media-security
    ORACLE(sdes-profile)#
  2. Use the crypto-list parameter to specify the crypto suite used for SDES-based encryption.
    Use either aria_cm_192_hmac_32, or aria_cm_192_hmac_32 to specify ARIA encryption.
    ORACLE(sdes-profile)# crypto-list aria_cm_192_hmac_80
  3. Use done, exit, and verify-config to complete cipher suite selection.
