Add-on Conferencing Configuration
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type
sip-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-config ORACLE(sip-config)#
From this point, you can configure SIP config parameters. To view all SIP config parameters, enter a ? at the system prompt.
- Type options followed by a Space.
After the Space, type the add-on conferencing information in the following format:
options refer-to-uri-prefix=”conf=”
For example:
ORACLE(sip-config)# options refer-to-uri-prefix=”conf”
- Press Enter.
