KPML-2833 Interworking on a SIP Interface Configuration To configure KPML - 2833 interworking on a SIP interface: Access the sip-interface configuration element. ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# sip-interface ORACLE(sip-interface)# Select the sip-interface object to edit. ORACLE(sip-interface)# select <RealmID>: 1: realm01 172.172.30.31:5060 selection: 1 ORACLE(sip-interface)# kpml-interworking—Set this parameter to enabled to use KPML-2833 interworking. Type done to save your configuration.
