Example 9 Status-Line Manipulation
This section shows an HMR configuration set up for status-line manipulation.
Given that the object of this example is to drop the 183 Session Progress response when it does not have SDP, your SIP manipulation configuration needs to:
- Search for the 183 Session Progress response
- Determine if the identified 183 Session Progress responses contain SDP; the Oracle® Enterprise Session Border Controller searches the 183 Session Progress responses where the content length is zero
- If the 183 Session Progress response does not contain SDP, change its status code to 699
- Drop all 699 responses
sip-manipulation
name manip
description
header-rule
name IsContentLength0
header-name Content-Length
action store
comparison-type pattern-rule
match-value 0
msg-type reply
new-value
methods
header-rule
name is183
header-name @status-line
action store
match-value
msg-type reply
new-value
methods
element-rule
name is183Code
parameter-name
type status-code
action store
match-val-type any
match-value 183
new-value
header-rule
name change183
action manipulate
comparison-type case-sensitive
match-value
msg-type reply
new-value
methods
element-rule
name make199
parameter-name
type status-code
action replace
match-val-type any
match-value $IsContentLength0 & $is183.$is183Code
new-value 199
sip-interface options dropResponse=699
