PreviousNextJavaScript must be enabled to correctly display this content
T.38 FAX Support
This release supports T.38 FAX relay (Version 0) conversion to T.30 over G.711 and supports FAX modulation schemes up to 14400 kbps V.17. The initial release does not support V.34 modulation.
