Authentication REPLY Packet
The TACACS+ daemon sends an authentication REPLY packet to the Oracle® Enterprise Session Border Controller in response to a authentication START or authentication CONTINUE packet. Depending on the contents of the status field, the authentication REPLY packet either ends the authentication transaction, or continues the transaction by requesting addition information needed by the authenticator.
The authentication REPLY packet format is as follows.
+-----------------------------------+ | Common Header | | | | type contains 0x1 | +--------+--------+--------+--------+ | (type field contains 0x1) | +--------+--------+-----------------+ | status | flags | server_msg_len | |--------+--------+--------+--------+ | data_len | server_msg ... | +-----------------+-----------------+ | data ... | +-----------------------------------+
status
This 16-bit field contains an enumerated value that specifies the current state of the authentication process. Supported values are as follows:
0x01 PASS — the user is authenticated, thus ending the session
0x02 FAIL — the user is rejected, thus ending the session
0x04 GETUSER — daemon request for the user name
0x05 GETPASS — daemon request for the user password
0x06 RESTART — restarts the transaction, possibly because the sequence number has wrapped, or possibly because the requested authentication type is not supported by the daemon
0x07 ERROR — reports an unrecoverable error
flags
This 8-bit field contains various flags that are not under user control.
server_msg_len
This 16-bit field contains the length of the server_msg field in octets. As the server_msg field is not used in REPLY packets sent by the current TACACS+ authentication implementation, the server_msg_len field always contains a value of 0 as specified in Section 4 of the TACACS+ draft RFC.
data_len
This 16-bit field contains the length of the data field in octets. As the data field is not used in REPLY packets sent by the current TACACS+ authentication implementation, the data_len field always contains a value of 0 as specified in Section 4 of the TACACS+ draft RFC.
server_msg
This optional variable length field contains a server message intended for display to the user. The current TACACS+ authentication implementation does not use this field.
data
This optional variable length field contains data pertinent to the authentication process. The current TACACS+ authentication implementation does not use this field.
