If you are adding this feature to an existing configuration, you will need to select the configuration you want to edit.
realm-id—Enter the name of a valid realm.
application-protocol—Enter a valid application protocol. There is no default for this parameter, and valid values are:
SIP or
H.323 .
access—Set this parameter to
permit (default).
trust-level—Set this parameter to
high, changing it from the default (none).
minimum-reserved-bandwidth—Enter the minimum reserved bandwidth you want for the session agent, and that will trigger the creation of a separate pipe for it. Only a non-zero value will allow the feature to work properly, along with the other required values set out in these instructions. The default is 0, and the maximum is 0xffffffff (or 4294967295).
