PreviousNextJavaScript must be enabled to correctly display this content
LMSD Interworking Configuration
You can apply
lmsd-interworking to the sip-interface facing the LMSD User Agents. For Example, if the endpoints uspporting LMSD are located in the core realm, then the
lmsd-interworking option would be added to the core
sip-interface.
To enable the LMSD Interworking option:
In Superuser mode, type
configure terminal and press Enter.
options—Set the options parameter by typing options, a Space, the option name
lmsd-interworking
with a plus sign in front of it, and then press Enter.
ORACLE(sip-interface)# options +lmsd-interworking
If you type the option without the plus sign, you will overwrite any previously configured options. In order to append the new options to the realm configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
