PreviousNextJavaScript must be enabled to correctly display this content
Media State Checkpointing Configuration
To configure media state checkpointing across an HA node in the ACLI:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager
and press Enter to access the system-level configuration elements.
ORACLE(configure)# media-manager
Type
media-manager-config
and press Enter.
ORACLE(media-manager)# media-manager-config
red-flow-port—Enter the port number for checkpointing media flows associated with the HA interface. This is the port where media flow checkpoint message are sent and received.
Setting this field to
0 disables media state checkpointing. The default value is
1985. The valid range is:
