Specifying the Delivery Mode
As described in Delivery Modes, SCTP support two delivery modes, ordered and unordered.
From superuser mode, use the following command sequence to access network-parameters configuration mode.
ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# network-parameters ORACLE(network-parameters)#
Use the
sctp-send-mode parameter to select the preferred delivery mode.
Choose ordered or unordered.
ORACLE(network-parameters)# sctp-send-mode unordered ORACLE(network-parameters)#
Use
done,
exit, and
verify-config to complete delivery mode configuration.
ORACLE(network-parameters)# done ORACLE(system)# exit ORACLE(configure)# exit ORACLE(configure)# exit ORACLE# verify-config --------------------------------------------------------------------- Verification successful! No errors nor warnings in the configuration ORACLE #
