Media Supervision Traps
The Oracle® Enterprise Session Border Controller, when functioning as a border gateway, will send the following trap when the media supervision timer has expired. This behavior is disabled by default, but can be enabled by changing the media-supervision-traps parameter to enabled in the media-manager configuration element.
apSysMgmtMediaSupervisionTimerExpTrap NOTIFICATION-TYPE
OBJECTS { apSysMgmtCallId }
STATUS current
DESCRIPTION
" The trap will be generated when a media supervision timer
has expired. This behavior is disabled by default but may
be enabled by changing the 'media-supervision-traps'
parameter of the 'media-manager' configuration element. The
included object is the call identifer for the call which had
the timer expire."
::= { apSystemManagementMonitors 34 }
The system does not send this trap when functioning as an integrated Oracle® Enterprise Session Border Controller.
