show sipd tcp connections
The show sipd tcp connections command displays Transmission Control Protocol (TCP) connection information details on remote and local address/port and connection states for analysis. Oracle recommends that you use the command only during non-peak times or maintenance windows.
The show sipd tcp connections command displays all SIP/TCP connections including each connection's direction, type, state, local and remote addresses, SIP interface and IMS-AKA details. Arguments include:
- sip-interface—Optional parameter that limits output to sockets in the specified sip-interface
- start start—Integer indicating which connection to start displaying. This can be a negative number. When the number selected for the start variable is greater than the number of TCP connections, the system displays nothing.
- start-count start—Integer as per above plus the count integer, specifying how many TCP connections to display from the start.
- all—Display all of the sipd tcp connections. Exercise caution due to the possibility of consuming all CPU time; preferably use during a maintenance window
For example:
ORACLE# show sipd tcp connections
Dir Type State Local Address Remote Address sip-interface-id isImsaka
LISTEN TCP_LISTENING 172.16.101.149:5060 net172
in FORKED TCP_CONNECTED 172.16.101.149:5060 172.16.23.100:51678 net172
in FORKED TCP_CONNECTED 172.16.101.149:5060 172.16.23.100:51679 net172
in FORKED TCP_CONNECTED 172.16.101.149:5060 172.16.23.100:51727 net172
in FORKED TCP_CONNECTED 172.16.101.149:5060 172.16.23.100:51728 net172
in FORKED TCP_CONNECTED 172.16.101.149:5060 172.16.23.100:51729 net172
LISTEN TCP_LISTENING 192.168.101.149:5060 net192
out CONNECT TCP_CONNECTED 192.168.101.149:8192 192.168.23.100:5060 net192
Connections Displayed: 53
Total Connections: 53
