Single-Ended SRTP Termination Configuration
<sdesProfile name='sdes'
srtpAuth='enabled'
srtpEncrypt='enabled'
srtcpEncrypt='enabled'
mki='disabled'
egressOfferFormat='same-as-ingress'
useIngressSessionParams=''
options=''
key=''
salt=''
lastModifiedBy='admin@172.30.11.55'
lastModifiedDate='2013-03-04 19:29:40' objectId='21'>
<cipherSuites name='AES_CM_128_HMAC_SHA1_80'/>
key>sdes</key>
</sdesProfile>
<mediaSecPolicy name='sdes'
passThrough='disabled'
options=''
lastModifiedDate='2013-03-04 19:30:23' objectId='22'>
<inbound profile='sdes'
mode='srtp'
protocol='sdes'/>
<outbound profile='sdes'
mode='sdes'
protocol='sdes'/>
key>sdes</key>
</mediaSecPolicy>
realm-config
identifier peer
description
addr-prefix 192.168.0.0/16
network-interfaces M00:0
mm-in-realm enabled
mm-in-network enabled
mm-same-ip enabled
mm-in-system enabled
bw-cac-non-mm disabled
msm-release disabled
qos-enable disabled
generate-UDP-checksum disabled
max-bandwidth 0
fallback-bandwidth 0
max-priority-bandwidth 0
max-latency 0
max-jitter 0
max-packet-loss 0
observ-window-size 0
parent-realm
dns-realm
media-policy
media-sec-policy msp2
in-translationid
last-modified-by admin@console
last-modified-date 2009-11-10 15:38:19
