Installation Wizard
The Oracle Enterprise Session Border Controller Wizard provides a wizard for initial system setup. The wizard installs the following elements.
- Management IP address & Gateway IP address
- Web GUI
- High Availability settings
- Net-Net Central (NNC) access setting
This section provides information about the Installation Wizard and details a step-by-step procedure you can follow while using the Wizard.
