PreviousNextJavaScript must be enabled to correctly display this content
Set Lync Emergency Call Options on Realms, Session Agents, and SIP Interfaces
You can configure the
return_183_initial_invite
option on each
session-agent,
realm-config, or
sip-interface that
interacts with Microsoft Lync. This option is not recognized in the global
spl-config and is required for SPL functionality.
In Superuser mode,
type
configure
terminal, and press Enter.
