Example 11 Use of Remote and Local Port Information
The following example shows the configuration for remote and local port information. The goals of this configuration are to:
- Add LOCAL_PORT as a header parameter to the From header
- Add REMOTE_PORT as a header parameter to the From header
sip-manipulation name addOrigIp description header-rule name addIpParam header-name From action manipulate comparison-type case-sensitive match-value msg-type request new-value methods INVITE element-rule name addIpParam parameter-name newParam type header-param action add match-val-type any comparison-type case-sensitive match-value new-value $LOCAL_IP element-rule name addLocalPort parameter-name lport type header-param action add match-val-type any comparison-type case-sensitive match-value new-value $LOCAL_PORT element-rule name addRemotePort parameter-name rport type header-param action add match-val-type any comparison-type case-sensitive match-value new-value $REMOTE_PORT
