Type
media-profile
and press Enter. If you are adding this feature to a pre-existing media profile configuration, you will need to select and edit your media profile.
subname—Enter the subname value for this media profile. Information such as the rate or bandwidth value make convenient subname values. For example, you might set the
name of the media profile as PCMU and the
subname as 64k.
