PreviousNextJavaScript must be enabled to correctly display this content
Codec Policy Configuration with a Media Type with a Subname
To configure a codec policy with a media type with subname:
In Superuser mode, type configure terminal and press Enter.
ORACLE# configure terminal
Type media-manager and press Enter.
ORACLE(configure)# media-manager
Type codec-policy and press Enter.
ORACLE(media-manager)# codec-policy
Use the ACLI select command to select a codec policy.
ORACLE(codec-policy)# select 1
You may now enter a media profile with subname to any parameter in the codec policy that accepts a media profile.
allow-codecs—Enter a list of codecs that this codec policy allows or denies from passing through the Oracle® Enterprise Session Border Controller. To allow all codecs, enter an asterisk (*).
