Configuring Media Release Behind the Same IP Address
You need to configure both the mm-in-realm and mm-same-ip parameters for the realm:
- If the mm-in-realm parameter is disabled, the mm-same-ip parameter is ignored.
- If the mm-in-realm parameter is enabled and the mm-same-ip parameter is disabled, media will be managed in the realm but released if the two endpoints are behind the same IP address.
To configure media management:
