SIP Status
To configure a SIP status to Q.850 Reason with cause mapping:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router
Type
sip-q850-map and press Enter.
ORACLE(session-router)# sip-q850-map ORACLE(sip-q850-map)#
Type
entries and press Enter.
ORACLE(sip-q850-map)# entries ORACLE(sip-q850-map-entry)#
From here, you can view the entire menu for the SIP status to Q.850 Reason with cause mapping entries configuration by typing a ?.
sip-status—Set the SIP response code that you want to map to a particular Q.850 cause code and reason. There is no default, and the valid range is:
Minimum—100
Maximum—699
- q850-cause—Set the Q.850 cause code that you want to map to the SIP response code that you set in step 5. There is no default.
- q850-reason—Set the Q.850 reason corresponding to the Q.850 cause code that you set in step 6. There is no default. If your value has spaces between characters, then your entry must be surrounded by quotation marks.
- Repeat this process to create the number of local response map entries that you need.
Save and activate your configuration for changes to take effect.
To configure a Q.850 cause to a SIP status with reason mapping:
Type
Type
ORACLE(session-router)# q850-sip-map ORACLE(q850-sip-map)#
Type
ORACLE(q850-sip-map)# entries ORACLE(q850-sip-map-entry)#
From here, you can view the entire menu for the Q.850 cause to a SIP response code with reason mapping entries configuration by typing a ?.
- q850-cause—Set the Q.850 cause code that you want to map to a SIP status with reason. There is no default.
sip-status—Set the SIP response code to which you want to map the Q.850 cause that you set in step 5. There is no default, and the valid range is:
Minimum—100
Maximum—699
- sip-reason—Set the reason that you want to use with the SIP response code that you specified in step 6. There is no default. If your value has spaces between characters, then your entry must be surrounded by quotation marks.
To enable the Oracle® Enterprise Session Border Controller to add the Reason header for calls that require IWF:
Type
Type
iwf-config and press Enter.
ORACLE(session-router)# iwf-config ACMEPACKET(iwf-config)#
add-reason-header—Enable this parameter to add the Reason header. The default is
disabled. The valid values are:
enabled | disabled
- Save and activate your configuration for changes to take effect.
