Unique SDP Session ID Configuration
To enable unique SDP session ID in media-manager:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
media-manager
and press Enter.
ORACLE(configure)# media-manager ORACLE(media-manager)#
options—Set the options parameter by typing
options, a Space, the option name
unique-sdp-id
with a plus sign in front of it, and then press Enter.
ORACLE(media-manager)# options +unique-sdp-id
If you type the option without the plus sign, you will overwrite any previously configured options. In order to append the new options to the realm configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
- Save and activate your configuration.
