Creating a Custom Filter
Use the following procedure to create a custom filter on the Net-Net ESD.
To configure a filter(s):
In Superuser mode, type
configure terminal and press Enter.
ACMEPACKET# configure terminal
Type
session-router and press Enter to access the
session router-related objects.
ACMEPACKET(configure)# session-router ACMEPACKET(session-router)#
Type
filter-config and press Enter to access the
filter configuration-related attributes.
ACMEPACKET(session-router)# filter-config ACMEPACKET(filter-config)#
name—Enter a name to assign to this filter. Valid values are alpha-numeric characters. Default is blank.
ACMEPACKET(filter-config)# name FILTER1
You can use this filter name when configuring monitoring on a global-basis, or when monitoring session-agents and/or realms.address—Enter the IP address to apply to this filter. You can specify netmask if required. IP Address must be entered in dotted decimal format (0.0.0.0). Default is 0.0.0.0.
ACMEPACKET(filter-config)# address 1.1.1.1 (filters on IP address) ACMEPACKET(filter-config)# address 1.1.1.1/24 (filters on IP address and netmask)
user—Enter a phone number or user-part to apply to this filter. Valid values are numeric characters. Default is blank.
ACMEPACKET(filter-config)# user 5551212
You must specify either the phone number OR user part for the user attribute. If you want both the phone number AND user part to be filtered, you must create separate filters to set each value.
Enter
done to save the filter.
ACMEPACKET(filter-config)# done
Enter
exit to exit the filter configuration.
ACMEPACKET(filter-config)# exit
Enter
exit to exit the session-router configuration.
ACMEPACKET(session-router)# exit
Enter
exit to exit the configure mode.
ACMEPACKET(configure)# exit
Enter
save-config to save the filter configuration.
ACMEPACKET# save-config
Enter
activate-config to activate the filter
configuration.
ACMEPACKET# activate-config
