Changes to Storing Pattern Rule Values
Release S-C6.2.0 introduces changes to the framework for storing regular expression results within manipulation rules, altering the way the store action works. These changes are beneficial to performance.
In previous releases, when the store action is used, the Oracle® Enterprise Session Border Controller stores all values matching the regular expression defined in the match-value parameter for all headers. At runtime, the system evaluates all stored values to find the correct index.
Now, you no longer need to specify the store action. The simple fact of referencing another rule tells the system it must store a value. When SIP manipulation is used, the system first checks to see if any values require storing. The add action is an exception to this process; storing happens after a header is added.
When referring to a rule, that rule still needs to have a regular expression defined in the match-vale and the comparison type set to pattern-rule; else the default expression will be used.
