Key Usage List
This section defines the values you can use (as a list) in the key-usage-list parameter. You can configure the parameter with more than one of the possible values.
Value Description
digitalSignature
(default with keyEncipherment)
Used when the subject public key is used with a digital signature mechanism to support security services other than non-repudiation, certificate signing, or revocation information signing. Digital signature mechanisms are often used for entity authentication and data origin authentication with integrity.
nonRepudiation Used when the subject public key is used to verify digital signatures that provide a non-repudiation service protecting against the signing entity falsely denying some action, excluding certificate or CRL signing.
keyEncipherment
(default with digitalSignature)
Used with the subject public key is used for key transport. (For example, when an RSA key is to be used for key management.)
dataEncipherment Used with the subject public key is used for enciphering user data other than cryptographic keys.
keyAgreement Used with the subject public key is used key agreement. (For example, when a Diffie-Hellman key is to be used for a management key.)
encipherOnly The keyAgreement type must also be set.
Used with the subject public key is used only for enciphering data while performing key agreement.
decipherOnly The keyAgreement type must also be set.
Used with the subject public key is used only for deciphering data while performing key agreement.
