RFC 2833 Mode Configuration
To configure RFC 2833 mode:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the media-related configurations.
ORACLE(configure)# session-router
Type
h323
and press Enter.
ORACLE(session-router)# h323
Type
h323-stacks and press Enter.
ORACLE(h323)# h323-stacks ORACLE(h323-stack)#
From this point, you can configure H.323 stack parameters. To view all H.323 stack parameters, enter a ? at the system prompt.
rfc2833-mode—Set the RFC2833 mode. The default value is
transparent. The valid values are:
transparent:—The Oracle® Enterprise Session Border Controller and H.323 stack behave exactly the same way as before and the 2833 or UII negotiation is transparent to the Oracle® Enterprise Session Border Controller.
preferred—The H323 stack uses 2833 for DTMF transfer, which it signals in its TCS. However, the remote H323 endpoint makes the decision. If the endpoint supports 2833, 2833 is used. If not, the H.323 stack reverts back to using UII. You configure the payload format by configuring the h323-config element.
