PreviousNextJavaScript must be enabled to correctly display this content
Reject Action Configuration
To support the
reject action, two parameters in the session-router-config
allow you to set how many messages in a certain amount of time cause the
Oracle® Enterprise Session Border Controller to generate an SNMP trap.
To set the reject message number and time window:
In Superuser mode, type
configure terminal and press Enter.
reject-message-threshold—Enter the minimum number of message rejections allowed in the
reject-message-window time on the
Oracle® Enterprise Session Border Controller (when using the SIP manipulation action reject) before generating an SNMP trap. The default is 0, meaning this feature is disabled and no trap will be sent.
reject-message-window—Enter the time in seconds that defines the window for maximum message rejections allowed before generating an SNMP trap.
