PreviousNextJavaScript must be enabled to correctly display this content
ENUM LRT Responses
No special configuration is required for LRT to work for H.323 and IWF calls. You can configure the system to match ENUM/LRT responses against session agent groups, and then use those SAGs for routing.
To enable matching ENUM/LRT responses for H.323 SAG routing:
In Superuser mode, type
configure terminal, and press Enter.
enum-sag-match—Set this parameter to enabled if you want the
Oracle® Enterprise Session Border Controller to perform matching against the hostnames in ENUM/LRT lookup responses and session agent groups. If there is a match, the
Oracle® Enterprise Session Border Controller uses the matching SAG for routing. If no match is found, normal ENUM/LRT routing proceeds.
