Configure the Session Border Controller (SBC) Behind a Network Address Translation (NAT) Device Option
Configure one public-private address pair for each SIP interface that uses the Support for SBC Behind NAT SPL plug-in, as follows.
- The private IP address must be the same as the SIP interface IP address.
- The public IP address must be the public IP address of the NAT device.
Before You Begin
- Confirm that the SIP interface is configured.
- Confirm that you are in the Superuser mode.
To configure the SIP interface IP addresses:
