Importing a Certificate Using FTP
You can also put the certificate file in the directory /ramdrv and then execute the import-certificate command, or you can paste the certificate in PEM/Base64 format into the ACLI. If you paste the certificate, you may have to copy and paste it a portion at a time, rather than pasting the whole certificate at once.
To import the certificate using FTP:
