Creating User-Defined Ptime per Codec
To change the Oracle® Enterprise Session Border Controller’s default ptime for a specific codec, you must create a media profile configuration element. In the parameter parameter, you set the ptime to the value of your choosing.
The frames-per-packet parameter in the media profile configuration element is NOT used for setting a user defined ptime for that codec.To configure a new ptime value for a codec:
