RFC 2833 Payload for H.323
To configure the RFC 2833 payload in preferred mode:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the session-related configurations.
ORACLE(configure)# session-router
Type
h323
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# h323
From this point, you can configure global H.323 parameters. To view all H.323 configuration parameters, enter a ? at the system prompt.
rfc2833-payload—Enter a number that indicates the payload type the
Oracle® Enterprise Session Border Controller will use for RFC 2833 packets while interworking 2833 and UII. The default value is
101.
Minimum—96
Maximum—127
