RTC Support
This appendix summarizes real-time configuration (RTC) support status for the Oracle® Enterprise Session Border Controller . The table below lists which configuration elements are supported by RTC and which are not.
| ACLI Configuration Elements | Parameter Details |
| Access Control | |
| Accounting Config | |
| Authentication | |
| Certificate Record | |
| Class Profile | |
| Codec Policy | |
| DNS ALG Service | |
| DNS Config | |
| Enum | |
| External Policy Server | |
| H.323 |
The following H.323 stack subelement parameters are not RTC supported in that, if you save and activate a configuration, calls already in progress will be dropped. A reboot is required.
| Host Route | |
| IPSEC | |
| IWF | |
| Licensing | |
| Local Policy | |
| Local Response Map | |
| Local Routing Config | |
| Media Manager |
The Media Manager element is supported with the exception of the following parameters:
| Media Policy | |
| Media Profile | |
| Network Interface | |
| Net Management Control | |
| Network Parameters |
The Network Parameters element is supported with the exception of the following parameters:
| NTP Sync | |
| Packet Trace Config | |
| Q850 SIP Map | |
| Realm Config | |
| Redundancy Config |
The Redundancy Config element is supported with the exception of the following parameters:
| Session Agent | |
| Session Group | |
| Session Router | |
| Session Constraints | |
| Session Translation | |
| SIP Config |
The SIP Config element is supported with the exception of the following parameters:
| SIP Feature | |
| SIP Interface | collect>boot-state |
| SIP Manipulation | |
| SIP NAT |
The SIP NAT element is supported with the exception of the following parameters:
| SIP Response Map | |
| SNMP | |
| Static Flow | |
| Steering Pool | |
| Surrogate Agent | |
| System |
The System Config element is supported with the exception of the following parameters:
| Test Pattern Rule | |
| Test Policy | |
| Test Translation | |
| TLS Global | When configured to support MSRP over TLS, this configuration element is not RTC enabled. If a single TLS profile is used by both SIP and MSRP, RTC changes will be applied for the SIP TLS configuration ONLY. |
| TLS Profile | |
| Translation Rules | |
| Trap Receiver | |
