IDS Licensing
This feature requires the IDS Reporting license.
The following capabilities and restrictions of the license:- The following configuration parameters located in the
access control and
media manager configuration elements are only visible after installing the license:
- trap-on-demote-to-deny
- syslog-on-demote-to-deny
- cac-failure-threshold
- untrust-cac-failure-threshold
- Endpoint demotions based on admission control failures are only a valid option with the IDS License.
- The presence of the IDS license makes the apSysMgmtInetAddrWithReasonDOSTrap trap available and the apSysMgmtExpDOSTrap unavailable. WIthout an IDS licence installed, only the apSysMgmtExpDOSTrap trap is available.
- The Trust->Untrust and Untrust-Deny counters in the SIP ACLs’ statistics are visible regardless of the IDS license’s presence.
- The Demote Trust-Untrust and Demote Untrust-Deny collect records in the SIP ACL HDR groups are visible regardless of the IDS license’s presence.
- A GET operation can be preformed on the two MIB entries to view the global endpoint counter for Demotions from Trusted to Untrusted and from Untrusted to Deny regardless of the IDS license’s presence
