Configuring Realm Groups
To configure a realm group for selective early media suppression:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
media-manager
and press Enter.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
realm-group
and press Enter.
ORACLE(media-manager)# realm-group ORACLE(realm-group)#
- name—Enter the name of the realm group.
source-realm—Enter the list of one or more global/SIP realms that you want to designate as source realms for the purpose of blocking early media; this is the realm identifier value for the realms you want on the list. Values in this list refer to calling SDP realms; this parameter has no default. To enter more than one realm in the list, list all items separated by a comma and enclose the entire entry in quotation marks:
ORACLE(realm-group)# source-realm Private, Public
To add a realm to the list, use the plus sign (+) in front of each new entry.
ORACLE(realm-group)# source-realm +Private
You can also remove single items in the list by using the minus sign (-) directly in front of the realm identifier.
ORACLE(realm-group)# source-realm -Private
- destination-realm—Enter the list of one or more global/SIP realms that you want to designate as destination realms for the purpose of blocking early media; this is the realm identifier value for the realms you want on the list. Values in this list refer to called SDP realms; this parameter has no default. To enter more than one realm in the list, list all items separated by a comma and enclose the entire entry in quotation marks:
ORACLE(realm-group)# destination-realm +Private
ORACLE(realm-group)# destination-realm -Private
early-media-allow-direction—Set the direction for which early media is allowed for this realm group. Valid values are:
none—Turns off the feature for this realm group by blocking early media
reverse—Allows early media to flow from called to caller
both (default)—Allows early media to flow to/from called and caller
- Save and activate your configuration.
