Example Configuration: Bidirectional Static Flows
The configuration lines below present the configuration of two example static flows to be used for ICMP to a specific host through the Oracle® Enterprise Session Border Controller.
The following lines present the example configuration for the access to core side.
static-flow in-realm-id access description in-source 0.0.0.0 in-destination 10.1.215.63 out-realm-id core out-source 10.2.214.63 out-destination 10.2.214.51 protocol ICMP alg-type none start-port 0 end-port 0 flow-time-limit 0 initial-guard-timer 60 subsq-guard-timer 60 average-rate-limit 0
The following lines present the example configuration for the core to access side.
static-flow in-realm-id core description in-source 10.2.214.51 in-destination 10.2.214.63 out-realm-id access out-source 10.1.215.63 out-destination 0.0.0.0 protocol ICMP alg-type none start-port 0 end-port 0 flow-time-limit 0 initial-guard-timer 60 subsq-guard-timer 60 average-rate-limit 0
