Global Authentication Settings
To configure the global authentication settings:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
security and press Enter.
ORACLE(configure)# security
Type
authentication
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(security)# authentication ORACLE(authentication)#
From here, you can view the entire menu for the authentication configuration by typing a ?. You can set global parameters for authentication. You can also configure individual RADIUS servers; instructions for configuring RADIUS server appear in the next section.
type—Set the type of user authentication you want to use on this
Oracle® Enterprise Session Border Controller. The default value is
local. The valid values are:
local | radius
protocol—If you are using RADIUS user authentication, set the protocol type to use with your RADIUS server(s). The default is
pap. The valid values are:
pap | chap | mschapv2
source-port—Set the number of the port you want to use from message sent from the
Oracle® Enterprise Session Border Controller to the RADIUS server. The default value is 1812. The valid values are:
1645 | 1812
- allow-local-authorization—Set this parameter to enabled if you want the Oracle® Enterprise Session Border Controller to authorize users to enter Superuser (administrative) mode locally even when your RADIUS server does not return the ACME_USER_CLASS VSA or the Cisco-AVPair VSA. The default for this parameter is disabled.
