PreviousNextJavaScript must be enabled to correctly display this content
Applying a Codec Policy to a Realm
Once you have configured a codec policy, you apply it to a realm by configuration name.
To apply a codec policy to a realm:
In Superuser mode, type configure terminal and press Enter.
ORACLE# configure terminal
Type media-manager and press Enter.
ORACLE(configure)# media-manager
Type
realm-config and press Enter.
ORACLE(media-manager)# realm-config
codec-policy—Enter the name of the codec policy that you want to apply to this realm. This value is the same as the one you entered in the name parameter for the codec policy you want to use for this realm. There is no default for this parameter.
