SDES Profile Configuration
An SDES profile specifies the parameter values offered or accepted during SDES negotiation.
To configure SDES profile parameters:
From superuser mode, use the following command sequence to access
sdes-profile configuration mode.
ORACLE# configure terminal ORACLE(configure)# security ORACLE(security)# media-security ORACLE(media-security)# sdes-profile ORACLE(sdes-profile)#
Use the required
name parameter to provide a unique identifier
for this sdes-profile instance.
name enables the creation of multiple sdes-profile instances.
Use the
crypto-suite parameter to select the
algorithms accepted or offered by this sdes-profile.
SRTP authentication is not currently supported.Allowable values are:
AES_CM_128_HMAC_SHA1_80 (the default value)
supports AES/128 bit key for encryption and HMAC/SHA-1 80-bit digest for authentication
AES_CM_128_HMAC_SHA1_32
supports AES/128 bit key for encryption and HMAC/SHA-1 32-bit digest for authentication
- Because SRTP authentication is not currently supported, ignore the srtp-auth parameter.
Use the
srtp-encrypt parameter to enable or disable
the encryption of RTP packets.
With encryption enabled, the default condition, the Oracle® Enterprise Session Border Controller offers RTP encryption, and rejects an answer that contains an UNENCRYPTED_SRTP session parameter in the crypto attribute.
With encryption disabled, the Oracle® Enterprise Session Border Controller does not offer RTP encryption and includes an UNENCRYPTED_SRTP session parameter in the SDP crypto attribute; it accepts an answer that contains an UNENCRYPTED_SRTP session parameter.
Use the
srtcp-encrypt parameter to enable or disable
the encryption of RTCP packets.
With encryption enabled, the default condition, the Oracle® Enterprise Session Border Controller offers RTCP encryption, and rejects an answer that contains an UNENCRYPTED_SRTCP session parameter in the crypto attribute.
With encryption disabled, the Oracle® Enterprise Session Border Controller does not offer RTCP encryption and includes an UNENCRYPTED_SRTCP session parameter in the SDP crypto attribute; it accepts an answer that contains an UNENCRYPTED_SRTCP session parameter.
Use the
key and
salt parameters to generate the synchronous
key used to encrypt and decrypt SRTP/SRTCP traffic originated by the Net-Net
ESD. These concatentated values are passed to the remote SRTP peer as described
in
Protocol Overview. Upon
reception, the remote peer imputs the key and salt values to the negotiated
encryption algorithm (AES in the current implmentation), thus deriving the key
required to decrypt SRTP/SRTCP traffic received from the Oracle® Enterprise Session Border Controller.
The key parameter provides the basic keying material, while the salt (a bit string) provides the randomsess/entropy required by the encryption algorithm.
Use the
mki parameter to enable or disable the
inclusion of the MKI:length field in the SDP crypto attribute.
The master key identifier (MKI) is an optional field within the SDP crypto attribute that differentiates one key from another. MKI is expressed as a pair of decimal numbers in the form: |mki:mki_length| where mki is the MKI integer value and mki_length is the length of the MKI field in bytes.
The MKI field is necessary only if the SDES offer contains multiple keys within the crypto attribute.
Allowable values are enabled and disabled (the default).
enabled – an MKI field is sent within the crypto attribute (16 bytes maximum)
disabled – no MKI field is sent
Use the
egress-offer-format to specify the
egress offer format for this profile to use when you set the outbound mode in
the associated media security policy to
any (refer to
Media Security Policy Configuration. You can select one of two values:
If the media security policy requires the use of either RTP or SRTP, this paramater can be safely ignored. If the media security policy is permissive (the mode parameter is set to any), select one of the two supported values.
same-as-ingress (default), the Oracle® Enterprise Session Border Controller leaves the profile of the media lines unchanged
simultaneous-best-effort, the Oracle® Enterprise Session Border Controller inspects the incoming offer SDP and:
- Adds an RTP/SAVP media line for any media profile that has only the RTP/AVP media profile
- Adds an RTP/AVP media line for any media profile that has only the RTP/SAVP media profile
- Use done, exit, and verify-config to complete configuration of this SDES profile instance.
- Repeat Steps 1 through 8 to configure additional SDES profiles.
