Codec Reordering Configuration
When you configure codec ordering, the codec you set in either the session agent or realm configuration must match the name of a media profile configuration. If your configuration does not use media profiles, then the name of the preferred codec that you set must be one of the following:
- PCMU
- G726-32
- G723
- PCMA
- G722
- G728
- G729
If you configure this feature for a session agent, you must configure it for the associated realm as well. Otherwise, the feature will not work correctly.
