Configuring ldap-cfg-attributes
You use the ldap-cfg-attributes object in the ACLI to configure the Active Directory attribute name, next hop for routing SIP requests, the realm for the next hop, a regular expression pattern, and a format for the attribute value. You configure this object for LDAP search queries in the Active Directory.
To configure ldap-cfg-attributes:
In Superuser mode, type
configure terminal and press Enter.
ACMEPACKET# configure terminal -
Type
session-router
and press Enter to access the session router-related objects.
ACMEPACKET(configure)# session-router ACMEPACKET(session-router)# -
Type
ldap-config
and press Enter to access the LDAP configuration-related attributes.
ACMEPACKET(session-router)# ldap-config ACMEPACKET(ldap-config)# -
Type
ldap-transactions
and press Enter to access the LDAP transactions-related attributes.
ACMEPACKET(ldap-config)# ldap-transactions ACMEPACKET(ldap-transactions)# -
Type
ldap-cfg-attributes
and press Enter to access the LDAP configuration attributes.
ACMEPACKET(ldap-transactions)# ldap-cfg-attributes ACMEPACKET(ldap-cfg-attributes)#attribute-name—Enter the Active Directory attribute name. Default is blank. Valid values are alpha-numeric characters. Some examples of Active Directory attribute names are:
ipPhone and msRTCSIP-Line for Lync phone number
telephoneNumber for IP PBX phone number
mobile for Mobile phone number
XML Tag: name
ACMEPACKET(ldap-cfg-attributes)# attribute-name msRTCSIP-Linenext-hop—Enter the Active Directory’s next hop when routing SIP requests. Default is blank. Valid values are alpha-numeric characters. Some examples of the Active Directory’s next hop are:
SAG (Session Agent Group) name, specified by entering an sag: prefix
SA (Sesson Agent) name
IP Address
XML Tag: nextHop
ACMEPACKET(ldap-cfg-attributes)# next-hop sag:SA1realm—Enter the name of the realm associated with the next hop. This value determines the network interface to which to route the SIP request. Valid values are alpha-numeric characters. Default is blank.
XML Tag: realm
ACMEPACKET(ldap-cfg-attributes)# realm net165extraction-regex—Enter the regular expression pattern used to break down the string of digits in the phone number extracted from the request URI of the SIP request. The variables extracted from the phone number can be used in the attribute-value-format parameter. The default regex is "^\+?1?(\d{2})(\d{3})(\d{4})$". This value assumes that the phone number is a North American phone number specified in the E.164 format. It extracts three variables from the phone number:
$1 is the area code
$2 and $3 are the next 3 and 4 digits in the phone number
XML Tag: extractionRegex
ACMEPACKET(ldap-cfg-attributes)# extraction-regex ^\+?1?(\d{2})(\d{3})(\d{4})$attribute-value-format—Enter the format for the attribute value. These format values are extracted from the phone number using the extraction-regex parameter. The default parameter is "tel:+1$1$2$3". This value assumes that the phone number is a North American phone number specified in the E.164 format, and it recreates the phone number in E.164 format.
In addition to the E.164 format, Acme Packet's Active Directory uses other formats as well to store the phone numbers. You can customize the value specified for this parameter to enable successful queries for phone numbers in other formats.
XML Tag: valueFormat
ACMEPACKET(ldap-cfg-attributes)# attribute-value-format tel:+1$1$2$3
XML Example for ldap-cfg-attributes
<ldapCfgAttributes name='ldapquery' name='msRTCSIP-Line' nextHop='sag:SA1' realm='net1651' extractionRegex='^\+?1?(\d{2})(\d{3})(\d{4})$' attribute-value-format='tel:+1$1$2$3' </ldapCfgAttributes> -
