PreviousNextJavaScript must be enabled to correctly display this content
DTMF Configuration
DTMF support requires you to configure a media profile named telephone-event. This section shows you how to set it up.
To configure a telephone-event media profile:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the session-related configurations.
ORACLE(configure)# session-router
Type
media-profile
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# media-profile
From this point, you can configure parameters for media profiles. To view see all media profile configuration parameters, enter a
? at the system prompt.
name—Enter the name telephone-event and press Enter.
parameters—Enter the parameters to be applied for the codec; these are the digits that endpoints can support.
media-type—Leave the default media type set to audio.
payload-type—Set the payload type to
101, which is the dynamic payload type needed to support this feature.
transport—Leave the default transport protocol set to RTP/AVP.
frames-per-packet—You can leave this parameter set to
0 (default).
req-bandwidth—You can leave this parameter set to
0 (default).
