New Reserved Word
To allow you to search for carriage returns an new lines, the SIP HMR MIME feature also adds support for the reserved word $CRLF. Because you can search for these value and replace them, you also must be able to add them back in when necessary. Configuring $CRLF in the new-value parameter always resolves to /r/n, which you normally cannot otherwise enter through the ACLI.
