ASCII Authentication
The Oracle® Enterprise Session Border Controller initiates the authentication with an authentication START packet.
+-----------------------------------+ | Common Header | | minor_version contains 0x0 | | type contains 0x1 | +--------+--------+--------+--------+ |action |priv_lvl|authen_ |service | | | |type | | | 0x01 | 0x01 | 0x01 | 0x01 | |--------+--------+--------+--------+ |user_len|port_len|rem_addr|data_len| | | |_len | | | 0 | N | N | 0 | +--------+--------+--------+--------+ | port | | tty10 | +-----------------------------------+ | rem_addr | | localhost address | +-----------------------------------+
- The action field specifies the requested authentication action — 0x01 for TAC_PLUSAUTHEN_LOGIN (authentication of a user login).
- The priv_lvl field specifies the privilege level requested by the user — 0x01 for TAC_PLUS_PRIV_LVL_USER.
- The authen_type field specifies the authentication methodology — 0x01 for TAC_PLUS_AUTHEN_TYPE_ASCII (simple login).
- The service field specifies the requesting service — 0x01 for TAC_PLUS_AUTHEN_SVC_LOGIN (login service).
- The user_len and data_len fields contain a value of 0 , as required by the TACACS+ protocol.
- The port_len and rem_addr_len fields contain the length, in octets, of the port and rem_addr fields.
- The port field contains the name of the Oracle® Enterprise Session Border Controller port on which authentication is taking place. Following Cisco Systems convention, this field contains the string tty10 .
- The rem_addr field specifies the location of the user to be authenticated. This field contains the localhost address.
The TACACS+ daemon returns an authentication REPLY requesting the username.
+-----------------------------------+ | Common Header | | minor_version contains 0x0 | | type contains 0x1 | +--------+--------+-----------------+ | status | flags | server_msg_len | | 0x04 | | 0 | |--------+--------+-----------------+ | data_len | | 0 | +-----------------+
- The status field specifies a daemon request — 0x04 for TAC_PLUS_AUTH_STATUS_GETUSER (get username).
- The server_msg_len data_len fields both contain a value of 0 , as required by the TACACS+ protocol.
The Oracle® Enterprise Session Border Controllerresponds with an authentication CONTINUE packet.
+-----------------------------------+ | Common Header | | minor_version contains 0x0 | | type contains 0x1 | +-----------------+-----------------+ | user_msg_len | data_len | | | 0 | |--------+--------+-----------------+ | flags | user_msg ... | +--------+--------------------------+
- The user_msg_len field contains the length, in octets, of the user_msg field.
- The data_len field contains a value of 0 , as required by the TACACS+ protocol.
- The user_msg field contains the username to be authenticated.
The TCACS+ daemon returns a second authentication REPLY requesting the user password.
+-----------------------------------+ | Common Header | | minor_version contains 0x0 | | type contains 0x1 | +--------+--------+--------+--------+ | status | flags | server_msg_len | | 0x05 | | 0 | |--------+--------+--------+--------+ | data_len | | 0 | +-----------------+
- The status field specifies a daemon request — 0x05 for TAC_PLUS_AUTH_STATUS_GETPASS (get user password).
- The server_msg_len and data_len fields both contain a value of 0 , as required by the TACACS+ protocol.
The Oracle® Enterprise Session Border Controller responds with a second authentication CONTINUE packet.
+-----------------------------------+ | Common Header | | minor_version contains 0x0 | | type contains 0x1 | +-----------------+-----------------+ | user_msg_len | data_len | | | 0 | |--------+--------+--------+--------+ | flags | user_msg ... | +--------+--------------------------+
- The user_msg field contains the user password to be authenticated.
- Other, optional fields are not used.
The TACACS+ daemon returns a third authentication REPLY reporting the authentication result, and terminating the authentication session.
+-----------------------------------+ | Common Header | | minor_version contains 0x0 | | type contains 0x1 | +--------+--------+-----------------+ | status | flags | server_msg_len | | 0x01 | | 0 | |--------+--------+-----------------+ | data_len | | 0 | +-----------------+
- The status field specifies the authentication result — 0x01 for TAC_PLUS_AUTH_STATUS_PASS (authorization succeeds), or 0x02 for TAC_PLUS_AUTH_STATUS_FAIL (authorization fails).
- The server_msg_len , and data_len fields both contain a value of 0 , as required by the TACACS+ protocol.
