Anonymous SIP Requests Configuration
To enable support for anonymous SIP requests:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
sip-interface and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-interface ORACLE(sip-interface)#
Type
options +reg-via-key and press Enter.
ORACLE(sip-interface)# options +reg-via-key
If you type options reg-via-key without the plus (+) sign, you will remove any previously configured options. In order to append the new option to the options list, you must prepend the new option with a plus sign as shown in the example above.
- Save and activate your configuration.
