Media Sample Size Configuration
This section shows you how to configure media sample size preservation for the global H.323 configuration and for an individual H.323 interface (stack).
To enable media sample size preservation for the global H.323 configuration:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router
Type
h323
and press Enter.
ORACLE(session-router)# h323 ORACLE(h323)#
options—Set the options parameter by typing
options, a Space, the option name
forwardFSAceptedDataType
with a plus sign in front of it. Then press Enter.
ORACLE(h323)# options +forwardFSAcceptedDataType
If you type options and then the option value for either of these entries without the plus sign, you will overwrite any previously configured options. In order to append the new option to the h323 configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
Save and activate your configuration.
To enable media sample size preservation for an individual H.323 interface:
Type
Type
h323
and press Enter.
Type
h323-stacks
and press Enter.
ORACLE(h323)# h323-stacks ORACLE(h323-stack)#
If you are adding support for this feature to a pre-existing H.323 interface (stack), then you must select (using the ACLI select command) the one you want to edit.
ORACLE(h323-stack)# options +forwardFSAcceptedDataType
If you type options and then the option value for either of these entries without the plus sign, you will overwrite any previously configured options. In order to append the new option to the h323-stack configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
- Save and activate your configuration.
